hoping you all can lead me in the right direction.
using roboguide im curently using vision to pick blocks from a table and place them on another table. no problem there
but now i want to pick those blocks and other shaped blocks from the same container like part sorting.
my question is how do i set up the vision process to properly pick a block or a triangle?
Currently, iv tried to use 1 vision process and 2 gpm locater tools to recognize each block or triangle however there is only one teachable reference position in that vision process and i think i need to teach a reference position for each shaped block.
Do i need to create a completely separate vision process for each block that is different in shape?
