So, I just installed J541 Password Protection onto a production R30iB, and need to configure it. Since I haven't played with this before, I built a virtual clone in RoboGuide and started setting up passwords.
So far, I've been able to set up basic Install, Programmer, and Setup users. But for the more granular control, making custom user levels, I apparently need to edit an XML file and import it. If I understand the manual correctly, I should be able to Export the XML file for the users I already have, then edit the file and Import it again. But when I try to use the Export function, I just get a "Passwords not set up" message.
Did I misunderstand the manual? Do I need to create the PASSLVL.XML file offline initially?
