Hello,I have a problem with configuration of a KRC5 controller as a master by profinet with Beckhoff EK9300 with EL1809 and EL2809 modules - slave
KUKA software packages:
Profinet M/S 6.0.6
KSS 8.7
It would be helpful if you could guide me through the integration and the configuration process.
So far I've had an error with invalid IP address on the beckhoff module in WorkVisual. "Error occured in DTM.PROFINET: Profinet. The ip adress of the device "ek9300" is invalid".
From what I know, KUKA has some IP ranges which are not available for other devices and the EK9300 module can only be configured as 172.16.17.0-255 according to the documentation available at: https://infosys.beckhoff.com/e…k9300/2608990475.html&id=
Not sure if this is the IP though. KUKA does not seem to be listing the forbidden IP addresses anywhere.
