So I'm very new to roboguide. I have been playing around with the software and was able to take a backup of one of our robots via usb through UT1and load it into the software. I wanted to test how to edit the TP programs in the software so I made a copy of an already existing program in roboguide and changed the name. I then loaded that newly named clone to my USB and tried to load it by itself to the real robot again using UT1. It shows up in the directory, but when I hit the load button it keeps telling me that it is not loadable. I have also tried this in a controlled start condition but gives me the same message. It does have the .TP extension so its not an .LS file but on the screen it shows up as Test.TP?. I'm not sure why the question mark is there. It's an R30iB controller by the way. Thanks for any and all advice.
Edited TP file to real robot from roboguide
K_Glide -
August 4, 2023 at 5:53 PM -
95devils
August 4, 2023 at 6:15 PM Approved the thread. -
It is looking like it may be an encryption issue when the files are moved into roboguide and than moved back to the USB. I'll contact the IT guys I guess.
AFAIK, the name of your file you are loading needs to be the same as the /PROG name in your program.
Is this the same?
If you renamed the file by just right clicking that won't work. You have to copy the program to another name.
Figured it out. It is an encryption issue on the USB that our IT department does. I have a request in for encryption bypass but was able to get the FTP working via WinSCP so that actually makes it more convenient anyway. Thanks for any and all input guys.
