Running Karel Programs without pressing shift or the deadman switch
  • First of all, I want to thank you all for the wonderful community.
    I recently wrote a Karel program to backup all files (including subfolders) on MC to a new folder in UD1.
    If there are any interests, I will share the file once I have the chance to test it.
    My question is:
    Is there a way to run the Karel program without having to hold the Deadman switch and the shift key?
    I am currently calling the backup program from a TP program.
    Using the RUN command allows me to release the shift key, but I am hoping to be able to run the backup program even in Auto mode.
    One idea comes to mind is to use a digital output to trigger the Karel program. Is there a more straightforward way to do so?
    Thank you in advance.
  • Place your Ad here!
  • For remote activation, you can trigger an KAREL program using an HTTP request from a web browser, or any program that can produce browser-style requests.
    http://Robot IP address/KAREL/KAREL Program Name?chVar1="Hello"&chVar2="World"
    chVar1 and chVar2 had to be declared in the KAREL file as String variables, with those exact names.
    The '?' is the separator between program name and variable list, '&' is separator between variables.
    Max 10 variables. Variables must be strings.
    Replace the bolded items with the robot IP and the name of the KAREL program. Variables are optional.
  • R47 Thank you for the suggestion. Running it with a Macro is a very logical step. I will most likely go this route.
    SkyeFire I wish our Robot was connected to the internet, but it is not at the moment. Thank you for the suggestion, it will come in handy one day.
  • SkyeFire I wish our Robot was connected to the internet, but it is not at the moment. Thank you for the suggestion, it will come in handy one day.
    I would not connect your robot to the internet. Not without very good firewalling. Robots don't get security patches the way PCs do.
    This trick is usable over a local network as well, however.
