INTERRUPT PROBLEM - ON BEFORE IT SHOULD BE
  • rvsh
  • June 27, 2023 at 3:50 PM
  • rvsh
    26
    I've got a problem. Tested on krc2 5.5.8 and 5.6.10 the same behaviour.
    The interrupt 23 in the program below is activated even when robot is on move to XP1. Is this normal behaviour of kuka robots?
    I turn interrupt ON AFTER the robot should reach XP1 and still the XP1 is interrupted when the robot is in move to XP1.
    I simplified the program to show how I use this interrupt. I added halt to check that the program really going into the ir sub and it confirmed that it goes there even when INTERRUPT is OFF.
    Where is the problem? Thank you for any input.
    DEF search()
      INI
      $CYCFLAG[1] = $IN[1] AND $IN[2]
      INTERRUPT DECL 23 WHEN $CYCFLAG[1] == FALSE DO irStopRobot()
      PTP $POS_ACT
      $ADVANCE = 3
      $BWDSTART=FALSE
      PDAT_ACT=PDATmax
      FDAT_ACT=FB1
      BAS(#PTP_PARAMS,100)
      PTP XP1 C_PTP
      INTERRUPT ON 23
      MoveP2()
      $ADVANCE = 3
      INTERRUPT OFF 23
    END
    DEF MoveP2()
      $BWDSTART=FALSE
      LDAT_ACT=Lcpdatmax
      FDAT_ACT=FB1
      BAS(#CP_PARAMS,0.08)
      LIN XP2
      $ADVANCE = 0
    END
    DEF irStopRobot()
      INTERRUPT OFF 23
      BRAKE
      rPickPosSavedZ = $POS_INT.Z
      halt
      RESUME
    END
    SkyeFire
    1,060
    9,454
    • June 27, 2023 at 4:29 PM
    Advance Run Pointer. Depending on the value of $ADVANCE, it "pre-loads" the next several motion commands (between 0 and 5, default value is 3), and pre-executes any non-motion code between those motions.
    Try making XP1 a non-CONT motion. Or place a WAIT SEC 0 between the XP1 move and the INTERRUPT ON command.
    If you absolutely must keep XP1 as a CONT motion, then you'll need to use a TRIGGER command to execute the INTERRUPT ON.
  • rvsh
    26
    • June 27, 2023 at 6:32 PM
    I thought until today that ADVANCE was only merging robot moves, and the "standard instructions" are executed between these moves and ofcourse advance pointer stops at instructions mentioned in KUKA expert manual as advance pointer stoppers. It was big misunderstunding on my side. Thank you for clarifying this.
    From your post I assume that instructions that do not stop ADVANCE pointer are executed in sequence until reaching the move that ADVANCE pointer point at, even that the moves are not executed yet.
    CONT is needed to get smooth movement. I will try TRIGGER tommorow. It looks promising. Thank you.
    SkyeFire
    1,060
    9,454
    • June 27, 2023 at 8:10 PM
    Quote from rvsh
    Correct. The ARP runs ahead of the Main Run Pointer and executes any non-Motion commands "in advance", until it hits a "breaking" command. WAITs are the most obvious "breaking" commands, but there's an entire list in the KUKA documentation.
    Upon hitting a "breaking" command, the ARP halts until the MRP catches up with it.
Similar Threads
  • Interrupt and Resume Program Control
    • macraesk
    • October 27, 2020 at 8:33 PM
    • KUKA Robot Forum
  • EthernetKRL Sometimes message is not received correctly
    • EmilijaS
    • March 8, 2023 at 10:38 AM
    • KUKA Robot Forum
  • Startup error new motion -12
    • Elderwild
    • December 2, 2022 at 6:48 PM
    • ABB Robot Forum
  • KUKA.ApplicationsKRC_1.2 installation failed
    • Gocea
    • April 22, 2022 at 9:08 PM
    • KUKA Robot Forum
  • POS_ACT and E6POS
    • Robotmei
    • January 11, 2022 at 4:00 PM
    • KUKA Robot Forum
  • EKI - PTP commands executing too slow
    • Ravnicas
    • January 10, 2022 at 10:46 AM
    • KUKA Robot Forum
  • RSI distance control with ANIN problem.
    • PiotrEDC
    • July 22, 2021 at 6:06 PM
    • KUKA Robot Forum
  • Unintended motion
    • Robottech
    • February 2, 2021 at 12:28 AM
    • Yaskawa Motoman Robot Forum
  • Different brake reactions when searching for one part
    • robotecnik
    • September 23, 2020 at 10:12 AM
    • KUKA Robot Forum
  • Using interrupt to store values
    • chis
    • February 25, 2020 at 11:10 PM
    • KUKA Robot Forum
  • interrupt
