  4. General Robotics Discussions - everything but NO Industrial Robots
Hybrid Ethernet and Power Connector
  • pmpopoviciu
  • June 15, 2023 at 5:39 PM
  • pmpopoviciu
    I am currently working on a robotics project that needs my robot to be connected to a ground station with Cat5e/Cat 6 ethernet and 48V 4 amp power. I've been searching around, and I can't find too many hybrid connectors that are able to fulfill my needs. Am I just looking in the wrong places? Or should I just stick with having two separate connectors and cables that are wrapped together?
  • panic mode June 15, 2023 at 5:57 PM
    Approved the thread.
  • panic mode
    1,263
    13,030
    • June 15, 2023 at 6:09 PM
    POE is good for up to 30W but your needs are 200W so that is not an option.
    so you need cable that can be used for Ethernet and elevated power levels. if you have the suitable cable and just need a connector, you can use any of the modular ones. for example it is very common to exchange data, IO or safety signals and power over such connectors when interfacing CNCs to a robot or PLC. one connector is housing several connector inserts with different polarity, pinout, etc. in fact it does not even need to be only electrical connections (can also include compressed air). so talk to your connector supplier (Harting, ILME, Weidmuller, Intercontec...).
    Here are some of examples of Harting (dominos)
    Han-Modular®: Twin angular housing ideal for motor connection | HARTING  Technology Group
    What are modular industrial connectors?
    The next level of modular industrial connectors | HARTING Technology Group
  • panic mode
    1,263
    13,030
    • June 15, 2023 at 6:57 PM
    https://conec.com/en/blog/conec-hybrid/
    https://conec.com/catalog/en/17312.html
  • Hardware
