Arguments .DT file - Wizard to Input Arguments
  • TomFoolious
  • June 14, 2023 at 3:53 AM
  • TomFoolious
    130
    Attempting to create a .DT file to show definitions of arguments for a CALL job...
    I have the ArcTool manual pulled up and I've written up a very similar example from what FANUC has, but after loading and cycle starting I'm not seeing my definitions show up with the CALL job.
    Here is the .DT file contents:
    [PROGRAM]
    PROGRAM = "MODEL_CHANGE"
    ARGUMENT = '4'
    [ARGUMENT]
    N01 = "G2 Home OFS"
    N02 = "G3 Home OFS"
    N03 = "G2 Work OFS"
    N04 = "G3 Work OFS"
    [ENDPROGRAM]
    I've loaded this into my virtual robot in Roboguide and cycled power, but not seeing my definitions come up when adding the Program Instruction "CALL MODEL_CHANGE" into my .TP job. Any idea what I'm doing wrong?
    Thank you to anyone who may provide help/insight,
    Tom
    P.S. I'm using v9.40 on my virtual robot.
  • AnandTUD
    39
    • June 14, 2023 at 12:00 PM
    Please check if the file has been loaded from MC: with the naming convention "ARGDISP(fixed) +
    EG(language) + 01(serial number) + .DT(extension)". Also check if the $ARGDISPMODE system variable is either 1 or 2.
    0 : Wizard to input arguments is disabled.
    1 : Wizard to input arguments is enabled. (Default)
    2 : Wizard to input arguments is enabled and the value of macro definition is displayed
  • TomFoolious
    130
    • June 14, 2023 at 12:36 PM
    Quote from AnandTUD
    I completely missed the naming part of that section in the manual, though I didn't see the variable in the manual. I did the correct naming convention and checked the variable (currently set to 1). Still no-go. I'll be digging in more tonight.
  • Nation
    Typical Robot Error
    522
    1,900
    • June 14, 2023 at 4:02 PM
    Attached is an example .DT file I've used in the past with success. I just changed the extension so it would upload.
    Files
    argdispeg01.txt 342 Byte – 72 Downloads
  • TomFoolious
    130
    • June 14, 2023 at 7:10 PM
    Quote from Nation
    Still can't get anything to show up, even using your file and creating a job called SAFE_PERCH. Perhaps this is a Roboguide bug. I doubt it is thoguh since RG runs a virtual controller.
  • TomFoolious
    130
    • June 14, 2023 at 7:47 PM
    I was able to see argument definitions on another instance of robots that I pulled in from a backdate. Perhaps it is a bug then. I'll consider this solved for now.
    I'm a big dummy and my mistake was in my original post...
    I was using PROGRAM = "PROGRAM_NAME" rather than NAME = "PROGRAM_NAME".
    Whoops.
    Edited once, last by TomFoolious (June 14, 2023 at 10:49 PM).
