  4. Kawasaki Robot Forum
K-Roset Crashing After Uploading Environment
  • boriskostov
  • May 15, 2023 at 11:15 AM
  • boriskostov
    5
    50
    when I try to upload an .stl file via Add -> Environment -> Works in K-Roset I get the following error:
    System.AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
    at MoNo.OpenGL.GL.glReadPixels(Int32 x, Int32 y, Int32 width, Int32 height, UInt32 format, UInt32 type, Void* pixels)
    at MoNo.OpenGL.MGL.ReadPixels(Box2i r, UInt32 format, GLDataType type, Void* pixels)
    at MoNo.OpenGL.MGL.ReadDepthPixels(Box2i r)
    at MoNo.GraphicsUT.GetMaxDepth(IView view, Box2i rect)
    at MoNo.GraphicsUT.PickScenes(IView view, Box2i rect, Boolean depthTest)
    at MoNo.GraphicsUT.PickScenes[T](IView view, Box2i rect, Boolean depthTest)
    at KHI.Fortuna.HisuiMain.MRailNew2.IdlingSelection.PickAt(IView view, Point2i pt)
    at KHI.Fortuna.HisuiMain.MRailNew2.SceneGraph.PickEntry(IView view, Point2i pt)
    at KHI.Fortuna.HisuiViewer.SceneViewerByHisui.PickEntry(IView view, Point2i pt)
    at KHI.Fortuna.HisuiViewer.SceneViewerByHisui.MouseClicked(Object sender, MouseEventArgs e, Boolean snap)
    at KHI.Fortuna.HisuiViewer.SceneViewerByHisui.<>c__DisplayClass23.<View_MouseClick>b__1f(Object sender, MouseEventArgs e)
    Does anybody had the same issue?
  • kwakisaki
    694
    4,770
    • May 15, 2023 at 11:31 AM
    What size is the STL?
    Do you have collision detection functions enabled?
    PC specification has impact on rendering, so make sure PC is high enough specification recommendation.
    KRoset struggles with large and detailed STL models, especially if using collision detection functions too.
    I use application called blender to reduce STL size and quality if I discover issues when importing STL's.
    Try:
    - Reducing quality of STL.
    - Ensure collision detection functions are disabled.
  • boriskostov
    5
    50
    • May 15, 2023 at 1:27 PM
    The files are from 120 KB to 37MB. For all files the software crashes;
    The collision detection function is off;
  • kwakisaki
    694
    4,770
    • May 15, 2023 at 1:39 PM
    Quote from boriskostov
    Doesn't that say something about the STL files then?
    Are you using a licensed dongle, trial version or operating it in lite mode?
    What are your PC specifications?
    What happens if you use any of the internal library models, does it still crash?
    What happens if you open up one or the demo projects, does it crash?
  • boriskostov
    5
    50
    • May 15, 2023 at 2:07 PM
    Probably Yes!
    License dongle!
    Intel(R) Core(TM) i5-8365U CPU @ 1.60GHz
    It crashes!
    It doesn't crash.
  • kwakisaki
    694
    4,770
    • May 15, 2023 at 2:18 PM
    So how do your PC specifications rate with the above recommendations and more importantly the specifications of the PC Models they have outlined and also the video card in use?
  • K-Roset
  • stl
