Stop program when position is reached
  • Hello.
    I have a main.src program that calls another program AxisScan.src
    In main.src i have declared a global interrupt that should detect errors:
    GLOBAL INTERRUPT DECL 4 WHEN RuntimeError==TRUE DO OnError()
    INTERRUPT ON 4
    The RuntimeError variable is declared in main.dat
    GLOBAL BOOL RuntimeError=TRUE;
    The OnError subprogram should stop movement, cancel programs and wait for signal from PLC before continuing execution of main.src.
    def OnError()
       BRAKE;
       wait for I_ResetRuntimeError;
       RuntimeError = false;
       O_RuntimeError = false;
       CONTINUE;
    end
    The AxisScan program is executed from a subprogram in main.src
    def ScanVertical()
       BAS(#BASE, DefaultBaseNo);
       BAS(#TOOL, SensorToolNo);
       AxisScan(V_S_Start, V_S_End);
    end
    The AxisScan program scans a part with a sensor mounted on the tool. The scanning process is stopped as soon as the robot gets a signal from the sensor.
    AxisScan program:
    StopScan looks like this and works. This cancels the DoScan subprogram and stops robot motion.
    def StopScan()
       brake F; Stop robot motion
       resume; Cancel all subprograms
    end
    The subprogram that executes the scanning movement looks like this
    def DoScan(target:IN)
       e6pos target;
       LIN target;
       RuntimeError = true; This should stop the AxisScan program
    end
    When RuntimeError is set to true i expect the robot to stop until a signal is detected from PLC and AxisScan to stop execution, but AxisScan continues execution and robot is never stopped.
    Can anyone help me on this?
    Edited 2 times, last by EiBru: Code blocks ().
  • MOM
    Approved the thread.
    • Helpful
    First, in StopScan(), make sure you actually want
    instead of simple brake.
    The reason why interrupt 4 never gets activated- interrupts are triggered by rising edge and you already have
    that I suspect is not set to false anywhere outside the interrupt routine.
