M-10iD10L
  • Edu.
  • May 4, 2023 at 3:54 PM
  • Edu.
    Hi everywone,
    I need some help with a few problems with my new fanuc robot.
    It started with "SRVO-062 BZAL alarm" in all axis. But that was solved.
    After that someone made changes on "System - Master Cal", but im not sure which ones. Press "Yes" on some of these:
    1. FIXTURE POSITION MASTER
    2. ZERO POSITION MASTER
    3. QUICK MASTER.
    6. SET QUICK MASTER REF.
    7. CALIBRATE.
    The robort wasn't in zero position.
    Now robot just make some noise and vibrations, and then shows "SRVO-050 Collision Detect alarm (G:1 A:3)", and "SRVO-053 Disturbance excess (G:1 A:3)." The robot could move in JOINT mode before de changes.
    Also shows the warning "Payload Configuration Not Complete".
    I think the robot thinks it's in a collision with itself, due to a bad position/zero calibration, but I have no idea. Can anyone help?
  • Lemster68 May 4, 2023 at 3:55 PM
    Approved the thread.
  • ROBOT_G
    23
    241
    • May 4, 2023 at 8:15 PM
    • Best Answer
    menu/0/system ---F1 type .....select variables.
    Scroll down to $DMR_GRP press enter twice
    The first variable is MASTER_DONE = TRUE
    Make it false
    It joint coordinate jog the robot to zero positions (witness marks)
    when finished
    Menu/0/system
    F1 type
    select master/cal
    zero position master
    then calibrate
  • ROBOT_G
    23
    241
    • May 4, 2023 at 8:19 PM
    if the robot doesnt have any payload for example a tool you can go into the payload settings
    menu/0/system
    F1 type
    select motion
    highlight payload [1] press detail
    change the first line PAYLOAD to = 0
    press the PREV key
    Press F5 SETIND
    1 then enter
  • Edu.
    • May 5, 2023 at 11:24 AM
    Hi!
    Thank you very much for the information, now I can move it! :grinning_face_with_smiling_eyes: :grinning_face_with_smiling_eyes:
  • mastering
  • SRVO-050
  • Zero Position
  • Payload Configuration
