I have taught my current program in UF 2 (164 points) with UT 1.
I would like to perform this 164 point program in an array pattern 5x3, 5 instances in the -Y and 3 instances in the -X (76.2mm in both directions).
Does anyone have any examples of an array program that they can share? I have successfully saved the initial program as a Text .LS file and edited it to moved it into UF3 but unfortunately I don't think this is the best way to achieve what I would like and it uses up all of my User Frames.
Thank you.
