Greetings- I have a application where my EOAT needs to be at a certain orientation while it is equipped due to cable management. Is there a way through DCS to limit the orientation of the tool plus or minus 10 degrees?
Fanuc EOAT orientation limits with or without DCS
TickTack -
April 13, 2023 at 4:28 PM -
If you want to do this with DCS then check the DCS manual for Joint Position Check and Orientation Check. One of these functions might be helpful.
Thanks for the input! Looking into this now, so is there a extra DCS option for Orientation check? or is that part of the Advance DCS package?
Orientation Check is part of the Cartesian Position Check function. It should be available when option J567 (DCS Pos/Speed Check) is installed on your controller.
I am from Europe and there is no Advanced DCS Package available*. However, I guess J567 is more or less the same as the Advanced Package and should therefore include the Orientation Check.
*EDIT: It is available but the name of the option is DCS Pos/Speed Check and not Advanced DCS Package.
Perfect, thank you! this works quite nicely for what was needed.
