Hi Team Fanuc
I have the error "I/O status is not cleared" and it's because of a Karel program. How can I reset this error knowing that I only have the PC files and I don't have the source files in KL
Thank you for help
Hi Team Fanuc
Thank you for help
without the source it is"problematic".
Did the progam work (sometimes)?
Maybe there is a problem with a file:
Are you opening/using files?
Or,are you communicating via sockets or pipes etc?
the karel built ins are:
IO_STATUS
CLR_IO_STAT
[in] file_id :FILE
status: IO_STATUS(file_id)
will return an integer different from "0" if an errror exists
CLR_IO_STAT(file_id)
will clear the errror
--> FCTN-->ABORT All | will clear the error too
best regards
PnsStarter
Thank for your reply, the program worked but when we changed the CPU of the controller and the emergency stop card, we have this error. I can’t CLEAR THE STATUS OF I/O because I don’t have the Karel program and I don’t know what’s in it.
We can’t passes from the pc file to Karel file ?
Best regards
