  4. Stäubli & Bosch Robot Forum
How to calculate z value in srs staubli ?
  • samu1995
  • February 21, 2023 at 7:13 PM
  • samu1995
    8
    i have a robot staubli tx 60, and i have a vision system that send a coordinate x,y and rotation around Z axes. i have some question ..
    1- why in srs 3d software the z axes decrement when the robot move down while in the real robot the z axes increment when the robot move down?
    2- How can i send a z of the picking point to the robot ? the z axes not start from a origin (0)
    3-when I teach the points from the pendant are they persistent when the application is restarted?
  • Lemster68 February 21, 2023 at 7:27 PM
    Approved the thread.
  • Lemster68 February 21, 2023 at 7:28 PM
    Moved the thread from forum General Discussion of Industrial Robots Only to forum Stäubli & Bosch Robot Forum.
  • ElEsgalho
    17
    119
    • February 22, 2023 at 4:32 PM
    There could be multiple different reasons for that to happen,
    1- The SRS tool and the real robot tool are different, please select the correct tool on SRS by navigating to it and right click and select as TCP
    2- There is no clear answer, you need to look at the programs and try to understand how the robot gets the vision position. Any change of sharing a backup?
    3- Again, it could be something inside the program forcing the point positions, once you change it on the pendant, and if you save, they should be persistent unless there is something in the program to change the value back.
  • Galet
    19
    141
    • February 25, 2023 at 2:15 PM
    Quote
    I'm agree with EIEsgalho. control the actual Frame and the actual tool...
    Quote
    On a Stäubli robot, the reference frame (World) is not on the floor but at the height of shoulder.
    Quote
    When you teach or modifie a point, you change it in the ram of the controler. If you want to keep the modifications after a switch Off/On, you need to save the application in the rom (disque)... If the value is forced in the program you need to change the program...
    Have a good day !
  • SRS
  • Z axes
  • picking point
