Hello.
I have a problem with Ethernet/IP option in RoboGuide. It seems like I can have it active only for 1 robot in RoboGuide. As long as first robot that booted up have connection, other robots have connectien status "OFFLINE". After I turn off that one robot, one of the rest can connect then. Anyone knows if this is a configuration problem - so it would be possible to use this option on many simulated robots - or is this a RoboGuide limitation?
I'm using adapter option for those robots.
