Is it possible to somehow block the standard user from editing the program. I have a problem lately of the type of adding new lines to the program by operators. Krc4 v8.2.16
Blocking program editing
Martin84 -
November 10, 2022 at 3:43 PM -
well on that KSS there is not much control. you can change the default passwords so that standard user cannot log in. you can then try couple of things like make the programs read only or move them to a folder that is hidden. just expose small program(s) used to calls them. another option is pretty elegant but not easy to do by hand - edit HMI configuration files so that command menu, touchup etc are not available to USer/Operator.
Rather, I meant the last option, edit HMI configuration. I used to do something similar on krc2, unfortunately it was a long time ago and I don't remember exactly. Usually the locations and names of the files are similar between krc2 and krc4 to the configuration. Can you tell me the file location and exact name pliku?
not the menu. in case of KRC2 they are INI files, on KRC4 they are XML files and structure is different.
make sure to make a backup of file before making changes
C:\KRC\SmartHMI\SmartHMI.exe.Standard.config
Thanks . Yes, I always make a copy
