  4. ABB Robot Forum
How do I send the actual position of an ABB robot via GO's to PLC
  • RoboRuben
  • October 19, 2022 at 3:05 PM
  • RoboRuben
    Dear,
    I want to make a clean function to send the actual position of the robot to the PLC. I want to do this via group outputs. (It is not that impirtant that the values are exact)
    I programmed something that works, but I'm sure you can make it cleaner in rapid. Has someone an Idea how I can send the actual position without the detour.
    (ABB, IRC5, Robotware 6.13)
    VAR intnum RAX1;
    VAR dnum nRAX1;
    VAR dnum rRAX1;
    VAR dnum sRAX1;
    Loop:
    ActPosCartTool0:=CRobT(\Tool:=tool0\WObj:=UserFrame0);
    ActPosJnt:=CJointT();
    RAX1:=ActPosJnt.robax.rax_1;
    nRAX1:=NumToDnum(RAX1);
    rRAX1:=RoundDnum(nRAX1);
    IF rRAX1<0 THEN
    sRAX1:=65535+rRax1;
    ELSE
    sRAX1:=rRax1;
    ENDIF
    SetGO GO1_CoordJ1,sRAX1;
    WaitTime 0.01;
    Lemster68
    301
    2,469
    Blog Articles
    7
    • October 19, 2022 at 3:20 PM
    There are already Rapid functions which can fetch the robot's position. CPos() gets trans, CRobT() gets the current robtarget position.
  • RoboRuben
    • October 19, 2022 at 3:49 PM
    Quote from Lemster68
    Sorry, but you've clearely not read the question. The question is how to send the data out of CRobT or CJointT to the PLC in Group outputs (16bit)?
    Lemster68
    301
    2,469
    Blog Articles
    7
    • October 19, 2022 at 4:53 PM
    So is the problem that you are having is that the DNum datatype is too large to send in a 16 bit group? The largest joint value possible ought to be no more than 400, so the Num datatype should suffice. If I had to do it, I would not map it as a group output, but as an analog representation of the value. With proper scaling, it should work fine. Not only that, but also, it will take care of the sign for you then too.
  • SomeTekk
    17
    202
    • October 20, 2022 at 7:43 PM
    Here's a possibility (Multitasking would be handy. YES, lots of RAPID code & data is not included):
    WHILE TRUE DO
    jT1:=CJointT(\TaskRef:=T_1Id);
    nAx1ToPLC:=Abs(Round(jT1.robax.rax_1\Dec:=0));
    IF jT1.robax.rax_1<0 SetDO do_RAX1Neg1,1;
    IF jT1.robax.rax_1>=0 SetDO do_RAX1Neg1,0;
    SetGO go_RAX1_CurJnt,nAx1ToPLC;
    ... 2, 3 ...
    ENDWHILE
    Edited 4 times, last by SomeTekk (October 27, 2022 at 2:05 PM).
  • position
  • Group Output
