We are using our robot for plasma cutting and would like to shift the z axis while the robot is running (from feedback of the torch and workpiece distance). Assuming that we already have the height value on PC, how can we shift the z height while running the robot (while the job is running)?
Shift frame while running/moving
tatatae -
September 15, 2022 at 9:06 AM -
If robot is running and is done a MOV instruction, only a Motoplus function can help you. You can write a program and use sensor function in Motoplus. when the robot is moving, every time you give the offset value for Z direction, robot want to change position in Z direction.
2 options
1) Sensor board with ACORON function. send analog value to the sensor board coming from the measuring height and robot can compensate accordingly
2) system job that calculate a frame constantly according to the values. your job must be relative according to that frame.
