  3. Cobot Help and Discussion Center
  4. KUKA LBR IIWA
set Additional Torque In Cartesian Impedance Control
  • Victoria
  • August 8, 2022 at 5:37 PM
  • Victoria
    Hello. I have a question related to adding a constant torque for a rotational degree of freedom (A)under impedance control
    Kuka iiwa is under impedance control in smart servo mode.
    I have set impedance parameters (Stiffness and damping ratio). I have been searching for finding a command for setting a constant torque in a cartesian impedance control mode. I came across The setAdditionalControlForce() and setBias() .
    I have tried The setAdditionalControlForce() but the path did not change in comparison with whenever I removed that command and Kuka worked without that additional torque.
    Do you have any idea about how I can add 1Nm in a rotational degree of freedom? (path is clockwise and the resisting torque is opposite)
    I have attached the part of the document related to this issue
    thanks for reading this problem.
  • panic mode August 8, 2022 at 6:01 PM
    Moved the thread from forum KUKA Robot Forum to forum KUKA LBR IIWA.
  • mabot
    17
    • August 25, 2022 at 9:39 AM
    Hello Victoria
    If the path depends on force which LBR add, then you can check direction(vector) to add the force.
    //setting parameters for impedance mode
    addingConstantForceMode = new CartesianSineImpedanceControlMode();
    addingConstantForceMode.parametrize(CartDOF.Z).setStiffness(0);
    addingConstantForceMode.parametrize(CartDOF.Z).setBias(1); //Nearly 1N
    In above code it push Z direction for example.
  • Victoria
    • August 25, 2022 at 4:21 PM
    Hello Mabot.
    Thank you for your response.
    Actually, I have found out that setAdditionalForceControl() works in smartServoLIN (linear)mode. but I cannot understand the actual procedure behind this command
    addingConstantForceMode = new CartesianLinImpedanceControlMode();
    for loop(){
    addingConstantForceMode.parametrize(CartDOF.A).setStiffness(10);
    addingConstantForceMode.parametrize(CartDOF.A).setAdditionalForceControl(1);
    addingConstantForceMode.setDestination(Frame); //just angular displacement
    I applied a geayer torque(10Nm) in an example to see the result better. actually, when it comes to setAdd... it shows an angular displacement with respect to Stiffness( before an unlimited position hold command ); but when I used this command in the for loop it does not change anything at all. And I want to know why KUKA works like this in this situation?
  • torque
  • smartServo
  • impedance control
