Hello
My robot's PC model is KCP ED05 because of having a data error and several other errors for the KRC. The KRC software is available inside the D file. Please guide the servant How can I clear the KRC and install the D file again
Hello
please be mindful with your posts. do not highjack other threads, double post or post in wrong forum.
if you have system that is corrupt the best and fastest way to recover is to restore known good backup.
if that is not the option proceed carefully:
1. BACKUP all you have.... create hdd image (backup just in case), try to create archive too if possible or at least collect one from D:\ (should be called INTERN.ZIP) and everything of value, including installers for KSS, tech options and copy of C:\KRC\ROBOTER\KRC
2. Run installer from D:\KSS_Release or similar
3. Restore MADA
4. install options
5. Backup again
