Hey All,
Sorry for being dumb. I have read other threads on using OVRD_SLCT. I go to CONFIG -> OVRD SLCT; when I cursor down to Signal 1/Signal 2 source, I am not getting an option to select the DI I want Signal 1 and 2 mapped to. When I would try to enable the OVRD_SLCT in the menu, it gave me the feedback "Invalid index..." because the values were uninit.
So, not being able to select DI or Enable the OVRD_SLCT, I went into System Vars and enabled it manually. However, even in the system variable menu, I am not getting a flyout menu to select the DI I want mapped.
What am I doing wrong or is there possibly some other system variable overriding me being able to select the DI for Signal 1 and Signal 2?
Just to be more clear: I am not trying to map a DI to the status of if OVRD_SLCT is enabled or not. I am just trying to map the DI used in the truth table for selecting the 4 speed options.
Thank you.
