Hello All,
I would like to upgrade/update my KUKA KRC4 software from version KSS8.2 to KSS8.6
- is this possible?
- how can i do this save?
I hope somebody can help me.
Kind Regards
Ron Kuypers
Hello All,
- is this possible?
Kind Regards
Ron Kuypers
I don't think an upgrade like this would be possible. PC hardware from both generations is pretty different.
It is possible, but costly.
If you have a KRC4 standard, you will require a new KPC installation, as well as the cost for the new software, and the cost of any tech packages you would like to update (required for new KSS). You will also most likely require a KUKA technician to come in and do the exchange.
I do not think you would need to exchange any other hardware in the controller.
Why do you need to update?
Have a look at this link, same problem:
It depends what PC hardware you have in the robot.
Its likely that since you are running KSS 8.2 that your hardware will be incompatible to get to KSS 8.6 but you may be able to upgrade to 8.5. You will see the MCC version of your KPC on your robot order
RE: Possibility of software update KR C4 cabinet
