Hi out there.
Just a quick question: 1) Is it true, that the term ELSEIF or ELSIF is not supported? I.e. if you have to check for multiple cases, you have to write like this:
Code
IF (a == 0) THEN
;Some thing happens.
ENDIF
IF (b == 0) THEN
;Some other things happens.
ELSE
;Else something else happens...
ENDIF
Would be nice to skip the "ENDIF" for each ELSEIF you want to apply.
Code
IF (a == 0) THEN
ELSIF (b == 0) THEN
ELSE
ENDIF
I now that alternatively, I could use a SWITCH CASE, but on the otherside, I just want to confirmed if this is true with the ELSEIF missing...
