Hi everyone!
Today we have a problem, the robot has broken bearings inside the JT1 shaft.
But we couldn't remove it (the bearing).
We do not have documentation on how to remove this part.
Someone here has the document please help us.
Hi everyone!
Please stop multi posting (I've removed your previous post).
Motor shaft is part of the motor assembly, that information regarding motor disassembly will never be made available from Kawasaki as the motors are manufactured elsewhere and the manufacturers are very unlikely to publish that information either unless you are a repair agent.
Just my opinion though - New motor.
If you are talking about the removal of the motor from the robot, it is just 4 bolts (and you will probably require to use stand off bolts to raise the motor).
Would recommend some sort of sling to assist in physically pulling it out though, depends on your accessibility and risk assessment to prevent any injury though.
I think the gear is on a tapered shaft and will require gear pulling equipment to remove without damage.
