DCS fences in T2 mode?
  • Tony R.
  • October 30, 2021 at 3:55 AM
  • Tony R.
    38
    Hi all,
    I‘ve been playing around with Dual Check Safety and someone wanted the robot to stop moving when the safety fence opens, unless In T1 mode. However, it seems to me that DCS is more connected to the teach pendant switch being on rather than a door signal itself. So for now, we‘re using BG logic to control this.
    Is DCS a safer way to approach this problem? Or am I fine using BG logic?
    Thanks in advance,
    Tony
    DS186
    200
    1,075
    • October 30, 2021 at 12:29 PM
    Hi Tony,
    I would strongly recommend using DCS for this, do not use BG Logic for that as it is not safe. You can create your individual safety functions in the Safe I/O Connect menu.
    DS186
    200
    1,075
    • October 30, 2021 at 12:31 PM
    Regarding your question about "DCS fences in T2", you can easily create a safety function to allow the robot to move in T2 only when the fence ist closed.
  • Tony R.
    38
    • October 31, 2021 at 11:25 AM
    Quote from DS186
    How might I go about setting this up?
    DS186
    200
    1,075
    • October 31, 2021 at 11:47 AM
    Program the below logic in your Safe I/O Connect menu to stop the robot with a category 1 stop in case T2 is active and fence is open:
    SSO1 (C_SVOFF) = SSI2 (FENCE) OR !SSI9 (T2)
  • Tony R.
    38
    • November 1, 2021 at 3:58 AM
    Quote from DS186
    Thanks man, that helped me alot!
Similar Threads
  • Disk memory fault 508 30 ( IRB 2000)
    • Hullhorst
    • August 17, 2021 at 9:20 PM
    • ABB Robot Forum
  • KRC4 Training safety wiring or programming in T1
    • dhracer3
    • March 30, 2021 at 10:40 PM
    • KUKA Robot Forum
  • Protected workspaces in Safe Operation
    • fabi
    • February 13, 2019 at 1:48 PM
    • KUKA Robot Forum
  • AD controller teach mode power on
    • griphand
    • May 30, 2018 at 2:36 PM
    • Kawasaki Robot Forum
