After reading thru the forums for a bit I am still stumped.
I have two virtual interfaces KLI and RSI. I was previously able to communicate to kukavarproxy using a fixed address at 192.168.1.99 on the same subnet as my computer.
After a reboot I can't get any connection to the bot. No pings reply, nothing.
I tried changing KLI to a dynamic IP and did a reboot, nothing shows. Link lights on switch and X66 are off.
Now I am trying to set KLI back to a fixed IP but cannot.
It says every time "IP address conflict, changes will not be saved"
I can try every IP address, as well as looking at my router to see open IP addresses, but same error.
I can even unplug the ethernet cable and it still has a conflict.
The big questions I have are:
How was I able to communicate to kukavarproxy on ip 192.168.1.99 if that was reserved to RSI? Shouldn't it have only worked on the KLI virtual interface?
What does the "Windows Interface" toggle actually do?
How can I see what dynamic IP address the kuka thinks it's getting?
Why does it say I have an IP conflict on virtual interface 5 if it's clearly not the same IP as virtual 6 and nothing else on the network conflicts?
Is there any way to confirm or PING from within the pendent to test connectivity over the LAN?
Thanks thanks, sorry for dumb questions
