Hello All,
This is my first brush with Fanuc / Roboguide so hopefully this isn't too obvious of an issue I'm missing.
I am trying to create a Roboguide cell from backups of two GM M-710iC/20L R-30iAs running software V7.30P/29.
They are both using DispenseTool H593 according to the backups (I don't yet have physical access to the robots and by the time I do it will be too late) but when I try to add a robot from backup file using the serialize wizard I get an error "The file backup requires H593 which is not a supported."
I have checked the available tools for every software version I have, and H593 only shows up under Robot Application/Tool on 7.4, 7.5, and 7.7.
I was able to get the backup to load in with H593 using OlpcPRO, but that doesn't do us any good as we need to teach paths before going on site for the job.
Am I missing something here or barking up a pointless tree?
I could just have my tech do the OLP on an almost identical 7.4 and copy the TPs over, but based on all my past experiences doing retrofit work on decade+ old installations, I'm hesitant to walk in without fully working backups to load in.
