KHI wants us to order their motor (which I found out later is a Sanyo Denki motor anyway) to be able to control an RTU as an external axis. Due to this being a demo cell with a smaller kawasaki RS007L , we ended up getting a ball screw linear actuator to act as an RTU instead due to time constraints and sourcing limitation from Kawasaki. What happens is that we now have a motor that has a shaft size of 22mm, but the linear actuator has a female input of 14mm with a NEMA 34 mounting. (https://vention.io/parts/enclosed…5mm-length-1283)
I'm thinking of getting a flexible coupling from McMaster, with one side 14mm and one side 22mm (https://www.mcmaster.com/couplings/flex…t-couplings-10/) And then couple that to a separate 14mm shaft with keyway that will go to the linear actuator side.
My questions are this:
- Is it okay if I forego the NEMA 34 plate mounting if I align the shaft and keyway in-line with the actuator and mount the motor directly onto the workcell floor?
- Anything else that I need to keep in mind or some recommendations when people are faced with this situation?
