I just finished a rough set up on our robots and i was wondering if there was a way to make it run bullseye at certain times of the day
How to make a timer for bullseye to run at certain times of the day
tjohnsonfrazier -
September 24, 2021 at 8:23 PM -
Is it being controlled by a PLC?
No it is not
Here is a little snippet for running something if it is the next day or more days:
IF stDate<>CDate() THEN
rWakey_Wakey;
stDate:=CDate();
ENDIF
I am looking for another example.
Here is another:
Display MoreIF stDate<>CDate() THEN MotionSup\On\TuneValue:=125; ELSE MotionSup\On\TuneValue:=100; ENDIF TPErase; stTime:=CTime(); stHour:=StrPart(stTime,1,2); stMinute:=StrPart(stTime,4,2); bOk := StrToVal(stHour,nTimeCurrentHour); bOk := StrToVal(stMinute, nTimeCurrentMin); IF nTimeCurrentHour <> nTimeLastHour OR (nTimeCurrentMin > nTimeLastMin +10) THEN MotionSup\On\TuneValue:=125; ELSE MotionSup\On\TuneValue:=100; ENDIF
The thing that you need to keep in mind is do not try to set a specific time unless you know that the robot will be available to run it or else you will rarely ever do bullseye. Set a time window when it can do it, between welding jobs.
thanks i will give that a try im wanting it to do it first thing in the morning before shift as we only run them on day shift
So im still fairly new at this programming, could you give me an example of it running a bullseye check at 6:00 am
Use the most recent code I posted and change the last part:
IF (nTimeCurrentHour = 6) AND (nTimeCurrentMin = 0) THEN
Bullseye;
ENDIF
thanks
BEQkChk;;
ENDIF
Honestly, run mine the beginning of every cycle... better safe then sorry
I would run every cycle but my cycle times are only 1 minute on one and 3 mins on the other
well that wouldnt be very efficient. lol
You could always create a counter. 30-50 cycles = bulleye
I guess it all depends how often you bend up the gooseneck.
