  4. ABB Robot Forum
How to make the DO signal value 0 when the ABB robot movement is stopped?
  • Angusli
  • August 25, 2021 at 5:13 AM
  • Angusli
    30
    ABB robot, system 6, model 1410, loaded with laser head, I am currently using IO signals to control the switching of the laser.
    The problem is that when the automatic mode is turned on, an anomaly occurs, the robot stops sharply but the IO signal cannot be interrupted, causing the laser head to stop at one point and output wildly, which is very dangerous.
    I hope you can tell me how to stop the machine and change the DO output value to 0, that is, turn off the laser head.
    At present, I use the shortcut key to turn off the laser head, but it still requires reaction time, which is not timely enough. Another consideration is to associate the IO signal with the system signal to control the shutdown, and associate the DO signal with the Mechanical Unit Not Moving state through the system output, so that the robot not only does not turn off the laser when it stops but also actively turns on the laser if the effect can be flipped.
  • Lemster68
    295
    2,458
    Blog Articles
    7
    • August 25, 2021 at 2:55 PM
    Cross connect the laser on output with the system output for program running, make your laser on virtual. Map another real bit which is to the laser. Both have to be on for the real output to turn on.
  • Angusli
    30
    • September 2, 2021 at 4:22 AM
    Quote from Lemster68
    Thank you! I solved my problem.
  • Lemster68
    295
    2,458
    Blog Articles
    7
    • September 2, 2021 at 1:54 PM
    You are welcome. :thumbs_up:
