Currently working on improving a couple things on our training cell (see this link to see the training cell) and I was pondering what everyone does when creating work spaces from scratch for a new application. Generally on our production equipment we don't modify the work spaces, although I have added a few basic ones sporadically. When I did create new or modify existing ones I more or less just jogged the robot around to get a approximate value for my cube. Not necessarily the most efficient way to do this. Does anyone have tips/tricks for setting up new work spaces? I have use of AutoCad and K-Roset and have been playing around with doing a rough layout in AutoCad and then creating a obstacle in K-Roset to sort of plot the Work Space in advance. Still feels like I'm doing a lot of guessing/eyeballing values. Any thoughts or suggestions would be appreciated.
Best practices when creating work spaces
ericwiz7923 -
July 27, 2021 at 5:37 PM -
I try and use the following method:
- A fabricated tool with the correct TCP to reflect the known tool, and the same in KROSET model.
- Accurate dimensioned cell layout modelling within KROSET.
- I create transparent 'boxes' to represent the actual workspace dimension using the shape generator.
- I then use the robot to 'teach the lower and upper corners (vertices) of the 'transparent box'.
- This then represents the 'actual size' and lower/upper limit values that I enter into the workspace fields.
- But instead I create a file for AUX DATA and put my workspace values in there and just load into the live robot and 'tweak' where required.
I'll have to go back and verify my TCP, that is a good point I hadn't thought of. Otherwise it sounds like I'm doing something pretty similar. Thanks for the feed back!
