Robot detecting range limit while still over a meter from the fence
  • As I ramp up the speed, over about 80 percent the robot detects that its going to hit the fence and gives a robot range limit error.
    Is there any way to make detecting the fence a little less sensitive?
    YRC1000 controller with a SP165-105 robot.
    Thanks for the assistance.
  • The tool interference file and the robot range are fairly accurate. If I drive it in teach it will stop just before the fence so it appears to be correct. That's why I am a bit confused on why is it detecting the robot range while being so far away.
  • I fought this a lot while i was starting out, what i have found is that different mov types will stop differently than others.
    MOVJ will stop much farther out than a MOVL,
    Also set your range limit to be true to the fence, since as you see now, the robot reaction will add a safety factor.
    The controller is looking at the path, speed, and the robot’s stopping distance as factors as when to stop. You are using a fairly large arm.
