FANUC R30iA; Uninitialized Data AND @ Not Displaying After Touching Up a Program Point P[1]
  • Koe
  • July 8, 2021 at 5:30 PM
  • Koe
    8
    This is about our R2000iB/165F with an R30iA controller and operating the SpotTool+ 7DA7/26 and Software edition V7.70P/26. After making a simple program (shown below) on the TP, I could not step forward through the program. It can run the first 2 commands, but no further. It says the INTP-311, the data is uninitialized. It also, will not dispaly @P[1] after creating a point or touching it up. The UT: 1 and GP1UF: 1 for all of the recorded points. When we press shift and record a point/touchup, it says that the point has been recorded, and the point position does change. The SHIFT Coord is set to User 1 and Tool 1, and the set coordinate system for jogging is set to USER.
    Program:
    UTOOL_Num = 1
    UFRAME_Num = 1
    L P[1] 200mm/s 100% FINE
    L P[2] 200mm/s 100% FINE
    L P[3] 200mm/s 100% FINE
    L P[4] 200mm/s 100% FINE
    [END]
    Question(s):
    * How can we initialize the data?
    - What are potential causes of uninitialized data?
    - What are potential causes of the software not recognizing that its position matches the recorded point in the program (no @ symbol)?
    - How can we change the equipment for the user frame? Currently, it is set to E1 on the top right of the TP screen.
    Background Info:
    * I am new to working on robotics. I've been working on this and we've only had the robot for a few weeks. So, a bit of a learning curve.
    * Bought 2nd hand through a surplus company. This is our first robot, and are trying to get this thing running for the least amount of money possible. We are not a large company, and this is not directly impacting our operations yet
    * Our software came with it, and has not been repurchased through FANUC.
    * This robot is eventually meant to be used with OLP software to assist in 3D path planning to route and trim plastic parts.
    Things we have tried:
    * Retouching Program and Recreating Program with current active User Frame. Added, removed, and added the commands defining the UTool and User Frames from the program.
    * Delete Old 7th Axis: (Wasn't there) The robot used to have a 7th axis for welding, but was bought with it already removed. Under control start, it is under group 2, but any attempts to delete a true 7th axis is met with it not existing. I believe the group exists, even though there is nothing under it. (Support, when looking at the position screen, there is no 7th axis shown)
    What we wanted to Check:
    * Could the uninitialized data come from the active equipment setting? If so, how do we change it so there is no active equipment?
  • Koe July 8, 2021 at 5:32 PM
    Changed the title of the thread from “FANUC R30iA; Uninitialized Data; @ Not Displaying After Touching Up a Program Point P[1]” to “FANUC R30iA; Uninitialized Data AND @ Not Displaying After Touching Up a Program Point P[1]”.
  • keyboard7
    162
    • July 8, 2021 at 6:34 PM
    You may have no more available memory left. But also one time we had corrupted memory.
    We had do do a back up to get rid of the corrupted memory. You can try and backup your programs to a memory card or laptop and delete some from your controller then try it again. The Fanuc tech told us that somehow blocks of memory become corrupted and cannot be used.
  • HawkME
    570
    3,269
    • July 8, 2021 at 7:22 PM
    Check the group mask in the 'detail' screen for that TP program and ensure it is set to (1,*,*,*,*).
    Also open up the position window for a point and post a screenshot.
  • Koe
    8
    • July 8, 2021 at 10:37 PM
    The issue was the group mask. It was set to (1,1,*,*,*). After fixing that, position was fully recognized and it was able to fully run. Thank you for your help!
  • teach points
  • R30iA
