Edit Field in AWE1WP01 file from KAREL + TPP
  • Use SET_VAR:
    SET_VAR (entry, 'AWE1WP03', 'SCH[2].$CMD_WFS', 5, STATUS)
    Thank You!!! This is code which work, now I need to make parsing parameter trough CALL.
    Edited 2 times, last by fmiroslav ().
  • For reading welding parameters from arguments you use:
    GET_TPE_PRM(arg_num, data_type, int_value, real_value, str_value, STATUS)
    Something like this, it's working but there is some another problem :(
    I would like to add (arg1) or insert (arg2) some value to string.
    For that purpose I want to convert Integer value to string (temp).
    CNV_INT_STR(arg1,1,1,temp)
    CNV_INT_STR(arg2,1,1,temp)
    and then to add and insert to string
    fname = 'AWE1WP0' + temp
    sch_num = 'SCH[' + temp + ']'
    sch_num_v = sch_num + '.$CMD_VOLTS'
    Trouble is temp is empty!
  • Third parameter was important, this code work for me
    CNV_INT_STR(arg2,1,0,temp_a2)
    temp_a2 = SUB_STR(temp_a2,2,1)
    Not a piece of artwork but...
    TPP program
    CALL SET_FA_WPP(6,3,1,22,181,100,30,23,181,101,31,24,182,102,32,2,50)
    Description of parameters
  • fmiroslav
    Changed the title of the thread from “Edit Field in AWE1WP01 file from KAREL + TTP” to “Edit Field in AWE1WP01 file from KAREL + TPP”.
  • Here is some trouble with input for real values,
    almost every real number is passing ok to data file,
    value ****.0 is problem!
    If type 20.0 in TPP (parameter in procedure CALL) that value is suppressed to 20 and
    valued as Integer, as result in data file is passed 0.00000E+00!
    If type 20.01 in TPP that will be passed as 2.00100E+01 and in
    weld procedure window I get 20.0 (trimed from 20.01000.
    Any Idea? Converting to string or...?
    GET_TPE_PRM(7, data_type, arg_int, real_value, string_value, status)
    arg7 = real_value
    WRITE('arg 7', arg7, ' ')
    SET_VAR (entry, fname, sch_4, arg7, STATUS)
    New code
  • Solved in Real number value *.0 can't be passed trought procedure CALL as real just as integer
