Hi guys,
We have a LR Mate 200 id to load our CNC with parts.
With our bigger and heavier parts we have some troubles.
First of all, how the robot is set now:
The max Payload for the robot is obviously 7kg. The Gripper itself is about 1.7kg and the gripped part itself is about 1.4kg, so both together about 3.1kg. Normal picking and placing of the robot isn't an issue at all. The fault appears at the reorientation with 100% Joint speed. The reorientation is from Homepos (-90, 0, 0, 0, -90, -90) to the Waitingpos in front of the loading window of the CNC (90, -75, 70, 0, -90, -90). I know the Waitingpos isn't the best Position for the robot, but we have very limited space to move in.
The Payload is set properly. I used the fanucs payload esitmation programm with known (weighted) mass. The part is about 150mm away from the flange.
The Fault:
The fault appears from to Waitingpos to the loadingpos in the CNC (99, 0, -26, 0, -63, -89.4).
The programm runs at 80% speed and the fault appears. With 100% run speed this fault appears: DIAG-005 Reducer load excess (G:1 A:2 L:91 P:Programmname.TP)
I can work with that settings, but I think the robot's lifetime is short, when we let it run 24/7 with this faults.
What can i do? My boss said, last option is reducing run speed.
Would it help to reduce the distance between the flange and the part (mass center)?
Thank you in advance
(and sorry for my bad english )
Kind Regards
pasu979
