KConVars error
  • SkyeFire
  • March 23, 2021 at 3:20 PM
  • SkyeFire
    1,044
    9,391
    On the side, I've been playing with building a script to iterate through an entire (real) robot backup and ASCII-convert all the convertable files. And I've gotten to the point where it works perfectly well, except on one file: POSREG.VR.
    For that one file, KConVars returns:
    Error executing KConvars: Conversion of variable file failed:
    0x10000B: Unknown
    My old RoboGuide install (from before my license expired) includes the correct core software version (8.33), and like I said, kconvars works on all the other .io, .sv, and .vr files in the backup. I've also tried making fresh backups of the robot, but I still get the same error.
    I also tried it on a backup from a completely different robot of the same version, and got the same error.
    I also got the same error trying on backups of robots with other versions, always on POSREG.VR.
    Just for sanity, I tried deliberately using a backup from a robot whose version I don't have in RoboGuide, and got a different error, "Unable to load old library."
    Anyone else ever run into this?
  • pdl
    266
    1,508
    • March 23, 2021 at 4:44 PM
    It sounds like the robot is available to you, do know that you can set the device to MD: and then just copy .VA of the variables, or just the specific ones you need?
  • SkyeFire
    1,044
    9,391
    • March 23, 2021 at 7:05 PM
    I was vaguely aware of that (in the MD/*.* sense), but the typical backups I encounter are where someone simply did the "all of the above" backup type. Plus, I'm indulging my curiousity in what I can do with the command-line tools if/when I don't have RG available.
    Still, that's good to know for future reference. Thanks!
Similar Threads
  • R-J CPU parity alarm
    • rjarc
    • October 10, 2018 at 12:09 PM
    • Fanuc Robot Forum
  • kconvars
