Hello everybody, this forum has been of much help, thanks! and sorry if this topic already exists...
I would like to know about the Variable Path CIRC command behavior, specifically, if this type of CIRC omits or not, part of the rotation components in order to get to the final orientation.
I will try to express it better: in the manual images (attached) for this type of CIRC it seems that the tool rotates in the axis normal to the plane that contains the circle (as the constant path CIRC does) and also that it rotates in the axis tangential to the circle in each point along with the move, but (this is my duobt) it seems that no rotation is made in the radial axis... in other words if the rotation in the radial axis is omitted the move won't reach to the orientation of the final point of CIRC command definition...
I hope I have expressed myself correctly... Thank you for your answers !!
