Working on integrating a RS003N into a training cell for my company. We are at the point of applying power now but ran into a little confusing situation. The XPOW (main 240VAC power) cables connections I have do not match what's listed in the F-series Controller Installation and Connection Manual. In the manual (page 48) it shows the wires as Black/White/Green(ground), My cable has two Black wires labeled 1 and 2 with a Ground. I'm assuming its fine to connect 1 to 240VAC and 2 to 0v common, but there's nothing I can find in the manual that states polarity does or does not matter so you can understand my hesitation to just assume. Any thoughts or suggestions?
Polarity of XPOW Cable (F-Controller)
ericwiz7923 -
February 12, 2021 at 3:02 PM -
Well internally they are referred to as:
- Line 1 (A1 of XPOW connector) which will be (black 1)
- Line 2 (A2 of XPOW connector) which will be (black 2)
- Earth (B1 and B2 of XPOW connector) which will be (green/yellow)
As you're feeding alternating current and the controller derives it's main power from a rectified DC of the input supply it does not matter about polarity on A1 or A2 of XPOW
In usual practices it is:
Line 1 = Line/Live (A1)
Line 2 = Neutral (A2)
Thank you for clarifying, I assumed as much but with this being my first integration I didn't want to go just off my assumption. By the end of this hopefully I wont be as much of a Rookie!
Some people live by the sword and assumptions sometimes can lead to falling on it.
Coin toss decisions sometimes give the pixies an opportunity to have fun.
Clarification keeps the sword in the sheath and the pixies locked up........Expert or Rookie.
