Hello, I’d like to know if it is possible to write files directly on the MC from a PC in Ethernet link (ftp or other...)?
Files on memorie card
serhum -
February 6, 2021 at 1:36 AM -
Yes, you can use FTP except on very old robots.
You can also use Telnet! The fact that Fanuc still supports Telnet always makes me smile and chuckle.
Telnet was developed in 1969
Thank for answers.
I dont know telnet but can be tested if it does not work in ftp.
What address should I use to access the memory card in ftp ?
Have i to change configuration on robot for activate ftp ?
What model of robot controller?
On the newer robots all you need to do is set a valid IP address in menu>host comm>tcp/ip. Then if your PC is on the same network you can use either command prompt, internet explorer, or a 3rd party ftp client such as Filezilla to send/receive files.
Note: you cannot send ".ls" files to the robot unless you have the ascii upload option.
Ok, this is version V7.7019.
The IP address is ok and my pc is on the same network.
I would do a test on Monday to see if I managed to access the memory card in FTP.
The purpose of my request is to simply manage the files on the memory card. With each change of recipe, the robot and camera programs are transferred from there.
Hello, login ok with filezilla in FTP.
You must first put "\" in the default remote folder.
Thank
