Can you guys recommend a grease pump?
Because hand pump is taking forever.
And gives you Popeye Arms too.
Too many grease pumps out there to specifically recommend.
- Consult Fanuc/Maintenance Manuals for maximum pressure values during replenishment.
- Research battery pumps or pneumatic which can regulate the required maximum pressure values.
- Too much pressure applied can cause damage to seals and motors.
I have never caused any damage using a hand pump before, so always take precautions when using pressure supply/generating pumps.
