GETARG-DX100
  • Toty
  • January 12, 2021 at 1:17 PM
  • Toty
    26
    Dear Community,
    I have MH 50 Roboter with a Dx100 Controller.
    in My (MASTERJOB) I have a different CALL with argument values as follows:
    /JOB
    //NAME MASTERJOB
    //POS
    ///NPOS 0,0,0,0,0,0
    ///TOOL 1
    ///POSTYPE PULSE
    ///PULSE
    //INST
    ///DATE 2009/10/13 22:54
    ///COMM UNTERPROG AUFRUF
    ///ATTR SC,RW
    ///GROUP1 RB1
    NOP
    CALL JOB:Ext4286
    CALL JOB:Ext4534
    CALL JOB:Ext1036
    CALL JOB:Ext2574
    END
    my Problem is that I can't find GETARG in my Inform List although I set it to to the EXTENDED; the Parameter (S2C 2110=2).
    I tried to write on my computer and to load that program to the robot, but I got Syntax failure.
    the Job that I wanted to load is simply
    /JOB
    //NAME EX
    //POS
    ///NPOS 0,0,0,0,0,0
    //INST
    ///DATE 2009/10/13 23:43
    ///ATTR SC,RW
    ///GROUP1 RB1
    NOP
    GETARG LB000, IARG#(1)
    END
    Is this instruction GETARG in DX100 also Optional? should I buy it from Motoman?
    I'm glad for your feedback!
    Thanks.
  • Toty
    26
    • January 12, 2021 at 1:56 PM
    resolved !
    in the header of the called program I forgot to define the arguments.
  • awoerpel
    5
    • December 28, 2021 at 11:29 PM
    Just as an added note: you need to allocate a local variable of whatever type your argument is in addition to actually creating the argument. At run time, the argument is stored in the local variable space that you had allocated. If you don't allocate some space, there is nowhere for the argument to be stored.
    While in your program
    • select: Display > Job Header
    • Scroll down to the < Local Var Num > section and allocate space what whatever type of arg you are passing.
    • select: Display > Argument Info
    • Define you argument
    Not sure if this is the same across all yaskawa controllers, but it was the process on my YRC1000
