Dear All
I am facing of oil leakage in sixth axis (Wrist) of Fanuc 2000iB /165 Kg Robot
We have replaced the wrist once .The new wrist also started leaking in 15 daus again
Can any one support
Regards
Adaptics
Dear All
Can any one support
Regards
Adaptics
How much oil is leaking?
The oil leakage started in small quantity hardly visible .But now it has increased and you can physically make out there is oil leakage all around the wrist. I haven't measured the qty
Did you use the correct grease? Did you apply too much or at too high of pressure?
Hope you followed the lubing rules or you cost yourself another seal and the tear down to replace. Good luck to you. As HawkMe said the pressure is the easiest thing to do wrong.
