soucis fanuc , statut erreur
marsh -
November 27, 2020 at 10:03 AM -
Je ne suis pas expert Fanuc, en revanche c'est un forum principalement anglophone, tu devrais reformuler ta demande en anglais, tu auras sans doutes plus de réponses comme ça.
These two errors seem to be related to the cause, the rest are just symptoms:
PRIO-091 E-Stop PCB comm error %x, %x, %x (hex)
Cause: Indicates that an error has been detected in communication between the MAIN PCB and Emergency stop PCB.
Remedy: - Check the cabling between the MAIN PCB and Emergency stop PCB.
- Replace the cable between MAIN PCB and Emergency stop PCB.
- Replace Emergency stop PCB.
- Replace the MAIN PCB.
SRVO-371 SVON2 status abnormal
Cause: A chain alarm was detected with the emergency stop board internal signal (SVON).
Remedy: Replace the emergency stop board.
Guessing from the error descriptions, either your e-stop board or the cabling to it is bad. What controller model do you have?
