Kuka is pausing for a while when sending the analog output command to PLC
  • issam dahaweir
  • September 30, 2020 at 10:55 AM
  • issam dahaweir
    16
    I have a kuka KR 360 L280-2 with kuka KRC02 ed05 controller (v5.6.11). I am using it as a 3d printer so that an extruder is linked to VFD and this VFD is connected to the robot via Delta PLC (slave module) in a CANbus network (500 Kbps). The PLC code is set to only receive from the robot and never send anything to it.
    In the code I send analog output command ($ANOUT[1]= 0.13875) to increase the speed of the extruder at certain layers.
    The problem is that when the robot reaches the analog output command line, it stops for a while then continues, and that is ruining the print !! on the other hand, when there is a command to increase the robot's movement velocity ($VEL.CP=0.01), the robot never stops. It increases the velocity while continuing its path.
    The question: is the pause coming from the lag of the CANbus network connection despite its 500Kbps bauderate? or there is a certain parameter I need to change?
    You can find a sample code I have tested recently, its about a long straight line divided into several lines in which in between I sent analog commands. Also, the acceleration parameter is set to maximum (I use Kuka PRC for slicing).
    Thank you
    Files
    testcode.txt 8.69 kB – 23 Downloads
  • issam dahaweir September 30, 2020 at 10:55 AM
    Changed the title of the thread from “Kuka is pausing a while when sending the analog output command to PLC” to “Kuka is pausing for a while when sending the analog output command to PLC”.
  • MOM
    176
    7
    1,424
    • September 30, 2020 at 11:16 AM
    every command which is talking to the periphery is causing a "stop".
    In order to prevent this you should do the following sequence (must looks like this - no empty line between):
    CONTINUE
    $ANOUT[1]= 0.1947602
  • Mentat
    61
    5
    243
    • September 30, 2020 at 11:41 AM
    Look into advance pointer to understand why this happens. You might also want to read about triggers if you want fine control over I/O during motion.
  • analog output
  • pausing
