Hi good morning Guys
We got a 2 abb m92 robots and controllers (Old bmw robots ), and i got 2 different questions
Question 1
robot A iam Trying to use it for a fiber glass application.
I was trying to sync the robot using bridgeing plug. But it does't want to enable.
pin configuration i got is( for bridgeing plug), no other io module is connected.
A1-B1
A2-B2
A3-B3
A4-B4
I tried the above, the enable doesent come on , iam not able to move the robot (jog the robot) to sync.
Is my bridging plug pin config right...do i need to check some thing else...
Question no 2:
The other M92 controller, i tried to connect it to an other robot , then it says..
"PROG Unit Communication Fault", and in the controller the red LED in ON on all the cards.
Is there any way to reset, the card. I tried just to connect controller-B to Robot A same type , same model.
Thanks in advance
paul from southafrica.
