TAST issue - Getting limit error on the line after TOUCH OFFSET
  • sanjay bisht
  • September 7, 2020 at 1:47 PM
  • sanjay bisht
    85
    Guys - I was trying TAST on my robot
    The program is running fine till line no 20
    Whenever it executes line 21 - TOUCH OFFSET PR 3
    It throws an LIMIT ERROR on next line 22
    My Point 18 P18 on line 22 is perfectly reachable - No axis is at its extreme , so i don't know why i am getting limit error. WHENEVER I skip line 21 and directly run line no. 22 , it goes to P18 without error.
    I am assuming that TOUCH OFFSET PR 3 is doing something to cause this issue.
    Any suggestion on what i am doing wrong....
  • Nation
    Typical Robot Error
    542
    1,924
    • September 7, 2020 at 3:26 PM
    What is inside PR3 when you run that line?
  • sanjay bisht
    85
    • September 9, 2020 at 7:21 AM
    its a fresh new PR, nothing inside it , I clear it before running the program
    It stores values during search right, LINE No 2??
    Thats how it works i guess
  • Nation
    Typical Robot Error
    542
    1,924
    • September 9, 2020 at 4:52 PM
    Yes, but what is inside of it when you finish the search? When you are on line 20 for example.
  • sanjay bisht
    85
    • September 10, 2020 at 5:29 AM
    i am new to TAST and i just copied this program from the Fanuc manual
    As per the instruction in the manual , i think when we run Search on line 2 , it stores the value of that position and then offset it on line 21 .
    When you say whats inside it ? should i got to PR 3 and try to move robot to PR3 position to check where it goes? or how can know whats inside it?
  • Erik Olsen
    54
    5
    177
    • September 10, 2020 at 6:38 PM
    Just run your search program and hold it while moving on line 20, then go to you Position registers under DATA and look at the data stored in PR[3].
    Are you trying to use the simple search? If so, this might be an issue with running the search in the Z direction.
    The example in the R30ib manuals only includes a two direction search and the snippet below indicates how it is used.
    Edited once, last by Erik Olsen (September 10, 2020 at 6:56 PM).
