Hello all,
Today I've tried to create copy of an existing robot via roboguide and i have this error message:
Any thoughts on that? (Web server works fine)
Hello all,
Why do you want to copy this robot? are you want trying to make two robots in the same workcell? if yes, would you like to use the cloning the robot rather than copy it.
Are you running roboguide as administrator? Can you create a robot from a file backup or do you get an error there too?
diey I would like to create new workcell from existing robot and check what options roboguide gives us when I have this connection.
TitusLepic Yes, I can create robot from backup file, but I'm not sure if I run roboguide as administrator (all roboguide features beside the one i'm writing about are working). Today my company's IT dept will try to check some network settings, maybe this will solve my problem.
Problem solved. I roboguide and internet explorer rules were blocked in firewall settings.
