Without actually seeing the issue I really don't have any suggestions other than check the robot to station calibration.
Shifting problem
alex1793 -
February 25, 2020 at 3:58 PM -
Can we see your job header data? From the jbi?
was this issue ever solved? what is the remedy?
I'm having the same problem. Does anyone have a solution?
did this issue start after you calibrated your tcp? did you calibrate coord+posture?
robotruler and alex1793 haven't logged on to this site since 2021, so I am not sure you will get an answer out of them. You may want to start a new post and provide the details of what is happening. Look through the previous posts on this thread to get an idea of the relevant information.
my solution was to input the old tool data for Rx,Ry,Rz and only calibrate in coord
