Hello friends. I have an ABB 6700 spot welding robot with an ARO gun. Robot gives servo Gun error. I changed the SMB cable but the error repeats intermittently. How can I fix this malfunction.
Servogun calibration problem
Dodo41 -
January 26, 2020 at 6:13 PM -
You tried to calibrate the gun?in position 0 manually and then click on SERVOGUN -> Update revolution counters ?
why did u change the cable smb?you have an issue with the cable or the servogun error appears until you change it?
What is the error number? Can you post a picture of the error screen?
Was the cable that was replaced between the SMB and servo gun?
